New Engine Options for Gen. 7 Camaro?
Pickles
Martin
Melbourne Australi
Audi RSQ3
Not much going on in this category. We Aussies rely upon you guys for the latest info,.....so what's going on?
So, what engine options are there?.....imho, as far as ZL1 is concerned, it's gonna have to be good to be better than LT4. I can see LS6 in the SS, but for ZL1, it will have to be something better than that,....so, what are the predictions,.....a supercharged LS6?
ls6 and 1 janky lifter. nothing else matters.
ARC
California
2023 Camaro
I don't think there will be an SS for 7th Gen.
LT - RWD 2.7 four banger 340hp
LTX - AWD 2.7 four banger with electric drive system for front wheels (rRay) 400hp
ZL1- RWD 6.7 v8 525 hp
ZL1X - AWD 6.7 V8 with electric drive system for front wheels (eRay) 665HP
GMs Nascar Camaro uses the ZL1 badge only.
I would be surprised if they did an E AWD only because you can already get AWD in Alpha. And unless they do a HUGE update on Alpha2 it wonā€˜t package the electric motor/drive axle AND a battery. That being said they haven’t offered AWD in any of the V or V Blackwings.
Now what you also have to account for is three brands and what differences they need to have to differentiate them and also justify cost differences. I outlined what GM did with LWB Lambda in another post.
I agree on the L4, base across the board most likely scenario. But we also have a 5.7 that can slip in there. Annnd a small matter of a miscellaneous turbo 6 cylinder (maybe the Cadillac V.
ARC
California
2023 Camaro
A turbo 3.6 v6 would underperform the new 6.7 v8 and likely cost more.
I assume the updated new chassis will be modified for front wheel electrification to expand into the wet and icy winter climates and increase sales.
The front electrification could help improve fuel economy and performance as GM ditches superchargers on top models.
Alpha architecture already has AWD. As I mentioned, I’m not sure there is room for an electric motor up front and a battery in the trunk just robs space. And then you get into the biggest issue and that is how differentiate a V Blackwing from a Camaro. Can’t be the same.
ARC
California
2023 Camaro
I assume the Blackwing will be the 6.7 with a performance hybrid for Awd as standard as the top Blackwing was the top ZL1 (C7 Z06 engine)
In this case ZL1X = Blackwing
GM is killing off superchargers and C8 Z06/ZR1 engines are too wide and won't fit in the Camaro/Caddy front engine bay.
So it might likely just be a single electric motor hooked up between the engine and transmission and use the extra power to push Awd using its existing driveshaft for that. Maybe beefed up for added performance.
DeuceCam
Richard
AZ
LT1
I don't think any info has been released by GM on the engines, but I could be wrong.
Of course, many of us want the new LS6 in some form. I want to see an LT6 available in some form, even if it's in a limited edition trim. However, I wouldn't be surprised if the decide to slap an LT2 in the SS, or whatever they end up calling it...
ARC
California
2023 Camaro
6.2 with AFM has such a bad reputation a new 6.7 with a big performance bump will help justify the 2028 $59,000 V8 base price.
4-door vs 2-door, detune the Camaro to have 15hp less.
ARC
California
2023 Camaro
I think the Camaro sedan will be a hatchback while Caddy keeps the trunk and only comes fully loaded.
you have to keep in mind what it takes to get you to move up to the Cadillac. 15 hp and a trunk don’t justify the cost. Don’t even think top end performance versions, what makes a Cadillac worth more than a Chevy or Buick. And the worse will be Chevy vs Buick. Look at the Trax vs Envista. It’s just styled different and the Buick gets a pan are rod rear suspension. That’s it.
ARC
California
2023 Camaro
Caddy people always lease, they care less about performance specs and more about status. Most likely they don't even know what motor is in their car.
1LEH8TR
Pennsylvania
2012 GT500
Is the updated LT4 slated to go out of production soon? If not, they could put that in the Camaro ZL1. We all know GM won't build a one off engine for the Camaro so they have to use what's available and unfortunately not supercharged V8's were made for the C8.
Nothing would make me less excited for the SS version then it coming with a 5.7 instead of the 6.7.
