Based on the 6th gen, what do you want Chevrolet to do better/include with the 7th gen Camaro?
Bandit
Dale
Georgia
77 Trans Am -- 2016 Silverado RCSB -- 2025 GMC Canyon
Visibility....I had a 2012 and 2015 Camaro SS and never could warm up to the smaller tighter interior on the 6th generation (and I really tried)....I wanted a Hyper Blue so I bad!
I like to see outside of the car a lot better and not feel cramped inside.
S3CRID
Flemming Island, FL
2017 Camaro 2LT, RS, A8, 3.6L
Most points I agree with.
I think we should keep the greenhouse coupe design because it’s a sports car not a mom car. It’s supposed to feel special.
The main things that need to change is the trunk opening and interior technology along with the interior storage.
emma84
burke
maryland
2021 camaro
keep it simple. Unless the 7th generation camaro is a perfect combination of the 5th and 6th camaro, or go retro and look exactly like 2nd generation camaro it will not sell. again. i'd rather chevy bring back the nova or the chevelle. but i have owned two 6th generation camaros and i love them. but, forget performance, thats for the corvette. i could careless about racing the mustang or nuemberg in germany. keep it simple, knobs and switches, no apple car play or andoid auto, V-6 350-400 hp is fine, V-8 455 hp is enought. make it look great, fix the beltline, improve back seat and trunk, keep it around 30-35,000$ max....keep it pony, keep it simple...
I think the electronic dash is a given, seeing as how everyone seems to be running in that direction. Part of me wonders if this is a fad like the electronic screens of the 80s, or if it's a real sea change. The biggest problem I have with the screens is that it's much harder to manipulate than a physical button, especially since the human body loves to use reference points via physical touch to orient itself. It's one of the biggest reasons we still have physical button keyboards instead of light keyboards or just flat panel LCD keyboards.
HUD is something I would like to see in the upscale versions.
comfortable supportive seats that hold you in place
A good sound system, or at least the ability to put a good one in.
at least yearly FULL updates for mapping systems. A lot of manufacturers these days (excluding things like apple and google maps) only update the areas you have been in. I was in a car that did that, and when I took an 1100 mile trip (one way) outside my immediate area, I had a real problem getting around. Had I not had physical maps and carplay, I could have easily gotten on the wrong roads or not been able to find my destination as my hotel had only been built 5 years prior.
High performance engines and good suspensions. I know there will be a 10-15 HP/FT-LB detune on it, but the Camaro or Chevy SS (whatever they eventually decide on) needs to have performance integrated into its design DNA.
I-SHIFT
Herb
British Columbia
2022 ZL1-1LE
Homelink
1LE or Z28 to have forced induction version of the C8 Z06 power unit
1LE to have the latest Mag ride from Cadillac
Keep the Tremec 6 speed
Suspension arms and components designed by Multimatic keeping the weight down
Fully adjustable front and rear camber adjustment
More tech - grab it from the C8
Agressive look.
345 section rear tires
325 up front
DeuceCam
Richard
AZ
LT1
Improvements/changes over Gen 6:
Actually be able to turn off onstar/etc. communication without ripping out the antenna - simple on/off button.
Good theft deterrence/alarm/security system.
Beefier rear diff/axle (8.8 or 9") standard for V8 cars.
Make the rear diff serviceable, i.e., don't weld the ring gear to the diff carrier..
Make the rear brake caliper/e-brake integration the same for all trim levels.
Round steering wheel.
DCT instead of torque converter for the "automatic" option.
Trim level or special edition with Z06 engine.
Dry sump, at least on 1LE package.
Wideband O2 sensors.
Port and direct injection.
No AFM. (If you must do it like Gen 6 then don't install AFM hardware on 6MT cars.)
Forged crank, rods, and pistons standard on V8 cars.
Higher compression ratio.
Higher redline and more top end power.
Ability to show multiple engine parameters/data points at a time on the scroll wheel section of the digital display.
More interior storage space.
More knee room.
Larger trunk opening.
Wider wheels/tires standard on V8 cars.
Don't pinch the exhaust tubes..
More knee room.
OnStar - not gonna happen
agree on security system
Axle - agree
rear brake-e-brake integration - agree. Keep part differential minimized
Round steering wheel - matter of choice
DCT - Not gonna happen except on halo cars. Too expensive and they have a 10 speed.
Possible halo engine
Port and Direct injection - exists on the LS6 6.7
AFM is going to happen. CAFE pretty much requires it for larger engines
Forged internals - yes, but the LS6 already has it
Compression ratio 13:1, so already has it
should get 500+hp/tq even if detuned slightly from the Corvette. Rev Limit should be 6,700 or so
A good user interface should be a priority...that said, no manufacturer has impressed me with designing a UI.
Internal storage space - yes, but if they keep the Camaro Coupe, this might be forced on the Buick version
see above for knee room
Larger trunk opening - yes, Even if you keep the trunk the same as the old Camaro, make it easier to get stuff in the trunk
Going to need wider tires for more power unless they go AWD -
Yes, but that's going to depend on how much they want to pay...
cooldawg
Doug
Indiana
Ex SS1LE
I loved the 6th gen especially in ZL1 1LE trim. More of the same (or at least very similar) please!
Direct and multiport injection (say hello to 6.7!).
More choice with respect to interior colors
Bright yellow must be available at all times
The gen 6 was a great car. Spend some resources to make that case. Don’t just let the car wither on the vine from a marketing perspective.
Keep it a pony car with two doors! Have a robust supply chain where cars can be built, ordered, and allocated.
Last but not least, build all the sold orders prior to shutting down the line! If they had built my car, I wouldn’t need to worry about a 7th gen…
I didn't know GM declined to build model year 2024 orders that were already accepted (2000 status), that would've been a silly amateur move.
The problem with your wish list and that of many others here is that such a car, much as we all love it, has a very limited customer base, and GM is unlikely to be content with making less profit on this would-be 7th gen Camaro than on their SUVs and trucks.
Also, their halo car is the Corvette and no Camaro will be allowed to reach a level of excellence as close to it as the 6th gen did.
cooldawg
Doug
Indiana
Ex SS1LE
I hesitated largely due to rumor that the CE cars were going to be bright yellow. Just to clarify (and in GM’s defense) after the dust settled, by ā€˜sold order’, I submitted my nitro yellow build to a high volume dealer in hopes it would be matched to an allocation. If memory serves, my order was never accepted, which means it never achieved 2000 status. That being said, why not allocate enough builds to customers in line to buy? Especially given an established product? Spilled milk, regardless.
I 100% agree with the points you made. The frustrating part is they didn’t market the car or go out of their way to sing its praises. I enjoyed my SS1LE. The visibility wasn’t an issue for me, it just wasn’t a ZLE or bright yellow.
DeuceCam
Richard
AZ
LT1
Not asking for a ton more interior space. Just need larger center console storage, somewhere to put a phone in front of the shifter, larger door pockets with cupholder, etc.
Emphasizing a round steering wheel (full circle). The d-shaped wheels feel cheap. Everytime I turn the wheel and grab the flat portion I'm reminded of how superior a round wheel is. Amazing how something so simple has such a large effect.
Make the 6MT shifter assembly serviceable from in the cabin. (It's ridiculous that the whole trans needs to be lowered (+ exhaust and ds) to get at the shifter on the 6th gen.)
Build necessary tolerances in the body panels so the rear bumper doesn't expand/contract like the 6th gen in the heat, and one doesn't have to be a magician to refit the rear bumper properly AND stay have it stay aligned after sitting in the sun..
Improve the wireless Android Auto/Apple Carplay connectivity (it's terrible on my Gen 6 to the point of being unusable).
Chris
2017 2ss 6speed
4 doors
Obviously 3rd row seating...
Rear captains chairs with their own media systems
More head room in the entire cabin
Taller suspension with 4wd
3 cup holders per seat
27in dash screen at minimum
Ditch the shitball unibody and get back to body on chassis like god intended it.
Would it hurt to have a diesel option?
Just really get rid of a lot of the sport and give it more utility.
It seems the unofficial "wireless charging pad consensus" for all vehicles is gravitating towards the location you want, ie under the HVAC control panel in front of the shifter, so chances are this will be taken care of if a new Camaro comes out.
It's the first time I see someone firmly believe a round steering wheel is superior or less "cheap". This is 100% a matter of individual perception, a D-shaped wheel isn't any cheaper or even less usable, while it provides more legroom under the wheel without making the wheel too small, which is important for low sports cars, especially when their cabin isn't shaped like a "bubble" like the Porsche or even the Mustang.
The easiest way to "fix" this would be to convince yourself that a flat bottom steering wheel is superior. The Corvette went one step further, flattening the top, too, and calling that "cheap" would be disingenuous, wouldn't it? :D
Rear bumper heat gap expansion was a design oversight, very unlikely to be repeated. It also has a proven redneck fix (zipties) that I applied in 2018 and haven't seen any gap or panel movement since then.
Not sure how good the wireless AA/CarPlay experience is in later model year Camaros, my 2018 didn't come with it, so I supported one of the first dongles (AAWireless) back when it was a kickstarter project, and even my early unit is flawless. I turn on the car, plop the phone on the charging pad, 5-6 seconds later it connects and everything works smoothly from then on. If the factory solution is unreliable, you might be able to use a similar dongle, they have come down really far in price these days.
